Hello Guest it is November 07, 2026, 07:34:14 PM
Author Topic: Need strobe signal on parallel port enabled.  (Read 10588 times)
« on: October 05, 2008, 01:57:48 AM »
After spending long hours and reverse engineering the PC Interface Board on my Emco Compact 5 PC, I discovered that the data inputs require an accompanying strobe signal in order to read the data.  As I recall the parallel port normally sends a strobe signal to the printer on this port with the data.  If there is any way to enable the strobe output concurrent with the data it will save me a lot of time designing and building a hardware kludge to work around the problem.
Doug Wilson (Calmissile)  dwilson@linkline.com
Re: Need strobe signal on parallel port enabled.
« Reply #1 on: October 05, 2008, 04:39:34 AM »
Hi
i got an article from a friend who has a compact 5 pc..
He got the machine running  with the old drivers...
MAybe this will help
regards
mcgyver
