Hello Guest it is November 22, 2026, 06:06:51 PM
Author Topic: We are having difficulty setting up the home switch settings.  (Read 24328 times)
We are new at Mach 3 and cannot seem to find the toggle to turn the m1, m2 and m3 home toggles on and off that the tutorial keeps asking us to do.  Is there a hot key?
Re: We are having difficulty setting up the home switch settings.
« Reply #1 on: October 05, 2008, 01:03:42 AM »
Do you have home/limit switches fitted?
« Reply #2 on: October 05, 2008, 09:24:14 AM »
educate me please.  We have a sensor on the gantry that I am assuming is the home/limit switches.
« Reply #3 on: October 05, 2008, 09:49:40 AM »
 I am unclear what you are meaning by the toggle to turn the home switches on. Home switches are used to reference your machine by pressing the Ref All button, your Z axis will move first, hit the switch, stop, reverse then stop when the switch again closes and the machine coordinates will be set. Then the Y, then X. You need to have your switches set up in ports and pins and also you may need to define the homing direction in Homing and Limits page.
« Reply #4 on: October 05, 2008, 01:33:19 PM »
I had to reload wxp  and have forgotten my config set up and having to retrain myself...
I have set my home sw and limit switches.......
Home and limit are same switch ..
.but when jogging I hit a limit  and stop ,,, I must manually move off the limit
I was thinking I could set some software switch so that when limit was hit machine would reverse off until off of limit switch and then EM stop
or did I dream this up......
where / what box do I check
« Reply #5 on: October 05, 2008, 01:39:35 PM »
Auto Limit Override is what you are wanting, should find it on the settings page.
« Reply #6 on: October 05, 2008, 01:41:09 PM »
Another thing you may wish to do is set up Soft Limits, that will stop you jogging onto and tripping a limit.
« Reply #7 on: October 05, 2008, 01:44:35 PM »
is this under config or where I'm having trouble finding it...
« Reply #8 on: October 05, 2008, 01:48:26 PM »
found it if its on settings-alt6
Thx
will set up soft limits also
« Reply #9 on: October 05, 2008, 02:23:57 PM »
new prob ,,, setting soft limits
jog moves properly  x -- moves left to home sw                  X+ move toward right side
                            z -- moves head up  toward home sw
                            y -- moves gantry toward home sw       Y+ move toward top of table
+Y
0---------+X
when I ref-all     z moves up  y moves in + direction and moves and moves  I reset to stop
What Am I doing wrong ......
