Hello Guest it is November 01, 2026, 10:06:20 AM
Author Topic: I'm missing somthng  (Read 11320 times)
Offline Psad
  •  82 82
I'm missing somthng
« on: June 18, 2006, 08:39:34 AM »
Brian somewhere im missing something and need some help.
I'm sending two files to you with simple DXF and Output Gcode.
before starting LZ i have tool number 1 with dia .25 (system set to inch), 0 tool height offset.
open LZ change holes to drill.
Layer control
tool = 1
final depth = -.25
rapid height =.25
start height = 0
Load G-code to Mach3
bring tool to work surface
zero all coordnates
start part
???? why in line N9 does it try to cut at +.15 not at - 25.
When it drills the holes the machien does go to -.25
puzzled  ???
Offline Psad
  •  82 82
Re: I'm missing somthng
« Reply #1 on: June 18, 2006, 08:42:51 AM »
sent dwg not DXF
« Reply #2 on: June 18, 2006, 10:43:51 AM »
There is a new rev of LCAM (2.54) that should fix the problem that you are having :) It should be out in a day or so.
Thank you for posting  the info!
Brian
www.newfangledsolutions.com
www.machsupport.com
