Hello Guest it is November 19, 2026, 04:06:25 AM
Author Topic: File name for a g-code conversion  (Read 25902 times)
MJR
« on: June 17, 2006, 10:35:59 PM »
I have been getting some g-code from one of my friends that he has converted into g-code from one of his design programs.  When I load the program there is no file name identifier.  I would like to edit the code (up-front, first-line) so I can quickly see if the right program loaded, as I will have several files that are somewhat similar in design.
What would I type in the first line so that it does not affect the program?
Thanks to all.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: File name for a g-code conversion
« Reply #1 on: June 18, 2006, 03:13:51 AM »
any text you want to display can be written in brackets, e.g.
(part number 123456/1)
Graham.
MJR
« Reply #2 on: June 18, 2006, 08:02:32 AM »
Thanks.  I will give it a try.
The first couple of times (brand new to Mach3) I imported a DXF file & did the g-code conversion (not LCam) a file name. in brackets was created, but I would get an error message, something about line zero, so I would delete that whole line & the program would work fine.  What may have been happening?
Thanks.
