Hello
Guest
it is
October 20, 2026, 03:06:43 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
DXF import
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: DXF import (Read 18922 times)
Vmax
DXF import
on:
December 14, 2005, 08:42:58 AM »
When I bring in a DXF 2d drawing how is the best way to control the Z axis. Do I just manually change the code for the different heights or can I set up the drawing and put the different height sections on separate layers before I import it?
? Thanks Terry Parker
Logged
Brian Barker
3,860
Re: DXF import
Reply #1 on:
December 14, 2005, 10:15:14 AM »
The best way is to use the layers for the depth's
Hope that helps
Brian
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Print
Pages:
1
Go Up
« previous
next »
