Hello Guest it is November 22, 2026, 02:44:09 AM
Author Topic: Conversational Wizard Problem  (Read 19542 times)
Brian
« on: June 16, 2006, 02:06:22 PM »
I have just installed the license file and my details appear in the about box. But when I press the Converstional buttion. It says that I am not licensed to use this wizard. Must I buy additional licenses for the wizards or am i missing something here? I am using Mach3 version D1.90.051
Re: Conversational Wizard Problem
« Reply #1 on: June 16, 2006, 04:48:58 PM »
The conversational wizard is from NFS and is a separate license. it is 50.00 and can be found at www.newfangledsolutions.com
Hope that helps
Brian
www.machsupport.com
« Reply #2 on: February 01, 2010, 03:57:42 PM »
I am currntly using v1.84.001 and have no problems, but was wondering if latest version (3.042.036?) has more wizards, what are they, and do I have to pay for upgrade?
Hilzy1
« Reply #3 on: February 01, 2010, 04:22:32 PM »
Dont think there are any more wizards but upgrading versions of Mach is free so nothing to lose by looking. Might want to copy rename your current Mach3 folder before you do the upgrade just in case something goes wrong, not likely but best to be safe.
« Reply #4 on: February 02, 2010, 07:51:17 PM »
There have been a number of bug fix versions of the wizards since the days of machV1.90
The latest wizards are now V2.83 see the section of this forum on Newfangled to get the latest version. Note that some recent versions of the Mach install have had an older (2.79) set of wizards. The version number will appear in the upper right cornet of teh first wizards screen
« Reply #5 on: February 03, 2010, 12:02:43 AM »
There is a Mach3 wizard list in Members Docs. Believe it covers all of the wizards for the mill. The file  has an associated graphics for each wizard.
