Hello Guest it is November 17, 2026, 01:08:25 PM
Author Topic: Changing Y axis to A axis  (Read 9804 times)
« on: September 27, 2008, 11:43:19 PM »
Anyone know how to tell Mach 3 to change the Y-axis to the A-axis without going through the whole code and doing it. What I want to do is take a flat pattern g-code and use it to cut the pattern in a tube. I know I can import the g-code into MS-Word and tell it to change all the (Y)s to (A)s. but there 's got to be a better way. Is there?
Thanks in advance
Jack
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Changing Y axis to A axis
« Reply #1 on: September 28, 2008, 01:39:21 PM »
you could go into ports and pins and assign pins from Y into A in a different profile.
Graham
« Reply #2 on: September 28, 2008, 07:41:10 PM »
Graham,
That is definitely another way to do it. I thank you Sir.
