Hello Guest it is November 23, 2026, 10:03:36 AM
Author Topic: program quits at 5K line every time  (Read 43132 times)
« on: September 26, 2008, 12:22:18 AM »
I am  novice and inserted a string of g code generated in sheetcam ,it is about 35K lines but consistently quits operation at precisely 5000lines.Is there some kind of "stop" at 5000 lines that is intentionally included or perhaps I have somehow triggered. Any help appreciated
Re: program quits at 5K line every time
« Reply #1 on: September 26, 2008, 12:48:33 AM »
It will be line 500 (lines in sheetCAM are probably numbered in 10's)
The demo version of Mill is limited to 500 lines and Turn 150.
If you have a licence it looks like you dont have it in your Mach3 folder, to check go to the Help menu then AboutMach3....   youwill then either see the name you registered with or it will say Demo.
« Reply #2 on: September 26, 2008, 12:59:51 AM »
My name is there I have a registered copy of Mach3
« Reply #3 on: September 26, 2008, 01:02:41 AM »
my name is there I have a recently registered copy
« Reply #4 on: September 26, 2008, 01:13:36 AM »
10 X9.4532 Y0.2992
N4920 X9.6091 Y0.3570
N4930 X9.6764
N4940 Y0.6373
N4950 X9.4758 Y0.8091
N4960 X9.4753 Y0.8101      Here is a snippet of code  total lines is 44990.
N4970 X9.4511 Y0.8831
N4980 X9.3592 Y0.8330
N4990 X9.5140 Y0.6994
N5000 X9.5157 Y0.6955
N5010 X9.5149 Y0.6914
N5020 X9.5118 Y0.6884
N5030 X9.5094 Y0.6874
N5040 X9.3531 Y0.6357
N5050 Y0.3858
N5060 X9.3520 Y0.3813
N5070 X9.3508 Y0.3796
N5080 X9.3490 Y0.3784
N5090 X9.3092 Y0.3570
N5100 X9.3490 Y0.3562
N5110 G00 Z0.2500
N5120
« Reply #5 on: September 26, 2008, 01:37:51 AM »
Please attach your xml and the full code.
 Also does the code (and Mach) just stop or does Mach do anything?
« Reply #6 on: September 26, 2008, 06:26:30 AM »
Line 5000 included in the post is actually the 500th line since the line #s increment by 10... if that's the number you are basing your observations on, the program has 4,499 lines.
If line 5000 is where it's stopping, sounds like a licensing issue.
Joe
« Reply #7 on: September 26, 2008, 09:08:36 AM »
Not quite sure what "xml" is . Sorry showing my ignorance it is the 500th line not the 5000 one. As far as mach goes.This is my first try at running mach3. First I ran the code generated by sheetcam without the machine actually running. several times. A few times it ran all the way through and but mostly stopped at the 500th line .the only time it did run through a couple of consequtive times I engages the machine and ran it physically .Tried this twice ,each time my machine worked well [Joe's 2006 model built last winter,with hobbycnc control] and just quit when it gets to line 500.
Mach just stops,seems to be doing fine up to line 500.
Not sure how to insert code .tried to paste it but that made the correspondance too big......thank you for the help  regards mike hide
« Reply #8 on: September 26, 2008, 09:47:31 AM »
OK your xml is in the Mach3 folder on your drive. If you are using a standard Mach3Mill profile the xml you want to attach is Mach3Mill.xml. You will however need to rename it as the forum will only accept a file name once and Mach3Mill.xml will have been used. To rename right click on the xml and choose copy then paste it to the desktop and right click again and choose rename and suggest you call it mike_hide.xml.  If you are using a custom profile the you need the xml that has that profiles name, ie *****.xml.
To attach files to the forum make sure you are using the full reply page and you will see additional options at the bottom left, click that then browse your drive to the files and choose them.
« Reply #9 on: September 26, 2008, 09:51:34 AM »
Go into your Mach3 folder (usually at c:\Mach3\) and copy the mach3mill.xml file to your desktop (right click the file and click "copy", switch to the desktop, right click and click "paste"). Select the file  on the desktop and hit f2 on your keyboard so you can rename the file. Rename it mikehide.xml, then upload by clicking "additional options" when you are replying to this thread.
Joe
