Hello Guest it is October 30, 2026, 12:35:06 PM
Author Topic: need help mach turn  (Read 16579 times)
need help mach turn
« on: September 21, 2008, 01:42:52 PM »
first time in mach turn. do i use the lazy cam to bring in the part to mach? i have tryed to bring in a dxf file out of autocad to lazy cam ,and the auto screen of mach, no success of bringing the part visible to either screen as well as g code. i watched the video on turn but still haveing issuses understanding. any help would be great!
thanks alex
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: need help mach turn
« Reply #1 on: September 21, 2008, 02:16:37 PM »
Hi Alex,
Lazycam has a limited amount of lathe tools, Lazyturn will be much better.
There are some rules to follow when importing profiles for turn in Lazycam, the profile has to be open and a single continuous line, it can not be a spline!
Make sure you output lines and arcs.  The picture is an example of a typical shape that will work fine.
Graham.
« Reply #2 on: September 21, 2008, 02:35:12 PM »
i could not find lazy turn on the site .where can i down loade the program?
thanks alex
  •  2,785 2,785
« Reply #3 on: September 21, 2008, 02:39:58 PM »
Have a look at this thread, its due to be released soon, there is a link in the LazyTurn thread to down load an taster version.
Graham.
http://www.machsupport.com/forum/index.php/topic,5767.0.html
« Reply #4 on: September 21, 2008, 02:51:09 PM »
i put in the folder rebooted rhe mach and lazy cam program opened mach and lazy cam up and tryed to open a dxf file and it said in the project window no project loaded.i am getting a little frustrated. thank you for your help. i learned how to use th new lazycam program for milling on this forum, it is a great place for help.
« Reply #5 on: September 21, 2008, 08:32:06 PM »
alex850,
Here is a link that will give you some info on using Lazycam for the lathe.
The first section should answer a lot of  questions.
http://www.machsupport.com/forum/index.php/topic,8426.0.html
