Hello Guest it is November 07, 2026, 07:56:14 PM
Author Topic: Constant surface speed without feedback  (Read 8835 times)
« on: September 19, 2008, 08:23:17 AM »
It should be possible to have constant surface speed without spindle feedback (turning mode).
If I consider that the real speed is equal to the spindle speed set up by mach, CSS should work.
In fact there is an option in the ports&pins -> spindle setup -> special functions
that have: Use spindle feedback in sync modes
If it is unchecked, it should do exactly what I mean, but it does not work, still expects the feedback.
Also this should be very easy to implement.
Filipe
