Hello Guest it is October 20, 2026, 02:55:30 PM
Author Topic: Cutter comp, comps backwards  (Read 12402 times)
« on: September 16, 2008, 11:56:22 PM »
i am trying to cut a 4" radius with a .375 end mill, when i set the part up i can offset the work and cut what i need to, in order to get the job done but i don't want to keep working this way.  i am trying to cut a counter clockwise arc with the tool to the left of the cut. i will post the code tomorrow and maybe we can figure this out.
Re: Cutter comp, comps backwards
« Reply #1 on: September 17, 2008, 12:25:14 AM »
That would be a g3. g41 which would cut the inside of your 4" radius.
Ed
Ed VanEss
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
« Reply #2 on: September 17, 2008, 04:36:20 AM »
Search on the forum - Graham Waterworth gave a comprehensive explanation of tool cutter compensation no more than 1 month ago which explained which code to use depending on your direction and left or right compensation.
