Hello Guest it is November 18, 2026, 05:20:35 PM
Author Topic: problems after g76 in turn  (Read 42944 times)
DaveDoesIT
Re: problems after g76 in turn
« Reply #20 on: September 17, 2008, 09:45:53 AM »
Here is the basic code I use to cut 20 tpi internal thread in 1.5 ID 4130 tubing.
Put G94 after the G76 call, I think it is still set to G95 from within G76. The fact it does the same on 3 machines means it is in the code. No?
« Reply #21 on: September 17, 2008, 05:49:40 PM »
Yep that works, for some reason I thought it would return to g94 after the thread cycle , will just add g94 to my post processor. thanks
Offline Vicke
  •  13 13
« Reply #22 on: September 18, 2008, 05:37:24 PM »
Would you like to make a short copy of the top of the program. Becaurse it is always nice to see G-code in real.
