Hello Guest it is November 01, 2026, 10:12:23 AM
Author Topic: UNRECOVERABLE ERROR MESSAGE  (Read 11244 times)
« on: September 15, 2008, 08:39:55 PM »
Just a few questions on Lazycam ( when using Turn): [ MACH R3.041, R3.042.003 - LazyCam V2.61, V3.00.2 ]
What happens in Lazcam to cause the " unrecoverable error in endgkdraw1 - notify Artsoft ...etc" to happen?
Are there any know combinations in particular or parameter settings inclusive of tool settings which would logicaly
trigger it?
Once it happens it can be a real pain to get lazcam to create profiles again without gettinig the error message.
Is there an easy way to "reset" lazycam so it works?
Would replacing the LCAM XML with one from when things were working well work?
« Last Edit: September 15, 2008, 09:16:23 PM by RICH »
Re: UNRECOVERABLE ERROR MESSAGE
« Reply #1 on: September 15, 2008, 08:52:49 PM »
Hey RICH, looks like you fell into your own spider web. :D Having FUN yet ? ;D
I wish I could answer you question.....but I CAN make it do that error EVERY STINKIN' TIME ! :P
Even did a fresh download today, same thing. :-[
Good Luck,
RC
« Reply #2 on: September 15, 2008, 09:13:00 PM »
RC,
Check out the testing I documented in the other post. I screwed up not one but "4" computers!
Now if you don't read it you'll never know what a possible fix is for it. ;D
I just can't believe I'm having this much fun...... ;)
All i wanted to do was a few screen captures  ??? and now only have bites on the backend from the spider! ;D
« Reply #3 on: September 16, 2008, 06:53:27 AM »
In LCam, which angle is which in ref to this diagram.
« Reply #4 on: September 21, 2008, 11:58:28 AM »
TO ALL,
trigger it?
To get it working again, answer no at the prompt to continue, go back into Lazycam and change the tool settings and parameters.
Then exit out and come back into Lazycam.
