Hello Guest it is November 26, 2026, 08:59:38 PM
Author Topic: Setting up Mach3 to drive Stepmaster controller  (Read 14270 times)
« on: September 11, 2008, 09:19:04 PM »
Need help with setting up Mach3 to drive Stepmaster controller. It worked correctly at one time, however I can't seem to find the right 'switch' to cause the controller to move the motors. I have read the documentation and watched the videos ( many times!). I believe I am missing something very elementary. Please help.
Re: Setting up Mach3 to drive Stepmaster controller
« Reply #1 on: September 12, 2008, 02:00:13 AM »
Please attach the xml for the profile you are using and we can have a look and see if there are any obvious errors.
« Reply #2 on: September 12, 2008, 09:21:10 PM »
Thanks! After re-reading the manual & some interpolation (I thank God for this!), I was able to get the router to move. I also had some direction problems. Thanx again!!
