Hello Guest it is October 07, 2026, 11:25:53 AM
Author Topic: How to round numbers  (Read 39145 times)
« on: September 08, 2008, 12:44:07 PM »
Hello friends,
How can I make this transformation:
1.3333 to 1.33 ???
I tried to use this code:
X=Round(GetDRO(0),2)
AB=Round(X*100)/100
Call SetOEMDRO(800,AB)
but the number I got  was 1.3300.
All that I wanted was 1.33.
Thanks for any support.
« Last Edit: September 08, 2008, 12:46:16 PM by azambuja »
Re: How to round numbers
« Reply #1 on: September 08, 2008, 12:57:16 PM »
Can you format your dro/s to only display two decimal places and then when it pulls the value from that DRO will it only use what is seen?
Just thinking out loud.
« Reply #2 on: September 08, 2008, 01:01:29 PM »
How can I format my DRO's?
I do not know how to do it.
If you know how, hepl me.
thanks
« Reply #3 on: September 08, 2008, 01:03:26 PM »
If this is a flash screen your dealing with, I can't help you.
« Reply #4 on: September 08, 2008, 01:05:08 PM »
Yes, it is a flash screen.
And thanks again.
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #5 on: September 08, 2008, 01:54:02 PM »
To format a DRO use:
Example will format DRO 104
Code: [Select]
fscommand( "DROFmt104", "%.0f")
To format to time based:
Example will format DRO 815 and 814
Code: [Select]
fscommand( "DROFmt815", "%D:%H:%M:%S")
fscommand( "DROFmt814", "%D:%H:%M:%S")
Jason Blake
« Last Edit: September 08, 2008, 02:01:34 PM by zealous »
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #6 on: September 08, 2008, 02:01:07 PM »
These are the formating parameters:
Days:Hours:Minutes:Seconds
Code: [Select]
"%D:%H:%M:%S"
(f)loating point number, (4) decimal points, (+) or -
Code: [Select]
"+%.4f"
integer, no decimals
Code: [Select]
"%i"
hex number
Code: [Select]
"%x"
Format to send the above:
fscommand( TYPE fmt DRO Number , ABOVE FORMAT )
Example:
fscommand ("DROFmt800" , "format" )
« Reply #7 on: September 08, 2008, 02:28:03 PM »
This was really helpfull.
Thanks a lot.
azambuja
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #8 on: September 11, 2008, 06:12:16 PM »
Great  ;D
« Reply #9 on: September 11, 2008, 06:13:35 PM »
Thanks for helping Jason.  :)
