Hello Guest it is October 21, 2026, 01:37:36 AM
Author Topic: Calculating Step For Mach  (Read 25268 times)
Re: Calculating Step For Mach
« Reply #10 on: April 08, 2010, 06:44:52 AM »
If you are calling one rev of the motor as 1 unit then 426,666/3,200 will be the steps per unit.
Edit sorry thats wrong, if 2000 line encoder thats 8000 per rev so if one rev is one unit then its 8000
« Last Edit: April 08, 2010, 06:48:31 AM by Hood »
« Reply #11 on: April 08, 2010, 06:49:28 AM »
again a little confused !!! cant we turn this servo continuous 3200 Rotation Per Minute ?? or 533.333 Rotation Per Second ?
« Reply #12 on: April 08, 2010, 06:54:03 AM »
if i set 8000 to "step per" it means that it will turn 3200 RPM right ? (for this calculation)
« Reply #13 on: April 08, 2010, 07:00:19 AM »
If you set the steps per at 8000 that means when you command a move of 1 unit per minute the motor will turn one revolution in one minute and the pulses sent out will be 8,000 per minute.
If you command a speed of 3,200 units per minute then that will be 8,000 x 3,200 = 25,600,000 pulses sent out per minute or 426,666 pulses per second.
Offline kf2qd
  •  157 157
« Reply #14 on: April 12, 2010, 02:58:52 PM »
Is this a spindle motor?
