Hello Guest it is November 12, 2026, 03:18:04 AM
Author Topic: Change scale on start up Mach3  (Read 11068 times)
« on: September 07, 2008, 07:42:12 AM »
I want change scale on X and Y axis when I turn on Mach3.
I do something like this
in Brain Editor
Estop ------ invert flip signal --------- Formula a*(1.0066) --------- Xscale
it works :)
buy I still will be looking for optimal solution
best regards
Marcin
Re: Change scale on start up Mach3
« Reply #1 on: September 07, 2008, 05:36:42 PM »
G51 sets a scale factor, so G51 X 1.0066 ought to do what you want. Put that into the init string thats in the Config/general screen and it will execute every time mach starts up. Might be safer to first do G50 to reset all scales to zero, then the G51.
« Reply #2 on: September 08, 2008, 10:24:58 AM »
Thank You both methods work good. If you say that Yous is more safe I will be use G50 G51 X1.0066 Y1.0066
once again thx
