Hello Guest it is October 22, 2026, 03:36:40 PM
Author Topic: VFD and noise questions  (Read 63977 times)
Re: VFD and noise questions
« Reply #30 on: September 01, 2008, 10:08:05 PM »
The two biggest settings were your max speed in config, spindle pulley and the velocity in config., motor tuning, spindle.
Glad your sorted.
« Last Edit: September 01, 2008, 10:10:43 PM by Chaoticone »
« Reply #31 on: September 01, 2008, 10:15:53 PM »
So what was causing the E-stop???
« Reply #32 on: September 02, 2008, 06:14:05 AM »
A conflict in the settings mentioned below and commanded spindle speed was causing the watchdor trigger. That is what was causing the e-stop.
« Reply #33 on: September 04, 2008, 03:46:15 PM »
Thanks for info about REF ALL HOME. I still can't seem to get back to making parts. I had the machine running today to tweak it in and after about 20 cycles the Y axis just quit. The DRO continued to run for Y but no movement. Can't even get it to go with the jog function. I have shut the drive down still nothing. Is there some kind of error log that might indicate what happened? I will restart Mach 3 and see what happens. I don't have the Sola on the drive supply yet.
B.E.N.
« Reply #34 on: September 04, 2008, 03:54:56 PM »
B.E.N.
Please reply in this thread , your posts have been split out to a thread of its own as it was off topic for this thread and also you are likely to get more views.
http://www.machsupport.com/forum/index.php/topic,8226.0.html
