Hello Guest it is November 13, 2026, 05:11:26 PM
Author Topic: XBox360 Controller New Version Available  (Read 57035 times)
Re: XBox360 Controller New Version Available
« Reply #10 on: February 08, 2009, 08:59:40 PM »
I'm experiencing a funny one while using the SS. When jogging with the keyboard, the axis will stop imediately.
When jogging using the zbox360 the axis won't stop unless i move the stick all the way to the other side and then the axis may reverse. Speed dosn't matter, even at a crawl. Seems like there is not much of a transitiion
between stick left or right.
Any experience around this or suggestions?
Is it a smoothstepper thing??
Offline Leed3
  •  162 162
« Reply #11 on: February 08, 2009, 10:29:16 PM »
Hi Rich and Chaoticone,
First of all, I have made the changes to the plugin that will allow reversing the direction.  I would like a couple of volunteers to test it for a few days and let me know if there is any problem with it before I give it to Artsoft for posting. Please email me and I'll send you a copy.
Things that can cause your problem are:
1. using version 1 of the plugin.  Make sure you are using the one on the MACH site
2. enabling the Shuttlepro at the same time as the XBox controller.  Mach3 wants only 1 thing at a time to control it
3. setting the slow jog rate really low
4. using a defective controller or one other than the Microsoft XBox360 controller
Try going to Control Panel - Game Controllers - Properties - Settings Tab - Calibrate - select Display Raw data check box.  The range of motion should be 0 to 65535.  If your max number is less than this then it is the controller. Let me know
Lee
« Reply #12 on: February 09, 2009, 03:05:00 PM »
Hi Leed3
I would like to volunteer to try it out . By the way I am Dan , also is there a way to disable the time out on the xbox controller,that is does not shout off?
Offline Leed3
  •  162 162
« Reply #13 on: February 09, 2009, 03:47:48 PM »
Hi Dan,
I have placed a copy on the Yahoo Mach3 forum in the files section.  Look in VS2005 - VS2008 / Lee's Files.  You should see the zip file there.
I do not know of any way to disable the timeout. Sorry.
Lee
« Reply #14 on: February 09, 2009, 05:03:33 PM »
Thanks Lee, I won't be able to test. I don't have a xbox controller and I'm pushed for time right now. Maybe I can later but hopefully some of the others will test this for you sooner than I can.
« Reply #15 on: February 09, 2009, 05:29:32 PM »
Lee,
I will be testing and maybe more so than i wanted to.   ;)
Sent you a PM.
As usual i seem to have a way to stick my finger somewhere and get it stuck!  ;D
« Reply #16 on: February 09, 2009, 05:50:41 PM »
Thanks RICH.
« Reply #17 on: February 10, 2009, 07:16:22 AM »
Hi Lee,
 I got the new zip file from the yahoo , with the revers direction blocks added works great I will fool with it some more and keep in touch.
Great job thanks
« Reply #18 on: February 10, 2009, 07:47:16 AM »
Thanks Dan.
« Reply #19 on: February 10, 2009, 09:08:48 PM »
Hi Lee,
Thanks for the info. The reversed axis mods seem to work great. Good going as
other users should find it helpfull.
I do have a few issues when using it along with the SmoothStepper but lets find out the
cause before posting anymore about it.
