Hello Guest it is November 22, 2026, 04:04:49 PM
Author Topic: layers  (Read 13016 times)
layers
« on: August 24, 2008, 04:41:00 PM »
I have a drawing in sheetcam with muliple layers, what order does Mach perform operations on then ,should they be numbered or are they performed as they are listed .....?   regards mike hide
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: layers
« Reply #1 on: August 25, 2008, 07:35:04 AM »
Hi Mike,
not sure what you are asking, Mach only runs g-code, the order of which is determined by the g-code creating program or person.  Lazycam on the other hand imports DXF files and produces g-code for Mach to run.
I never use Lazycam, others here are better qualified to advise you on its use.
Graham.
Re: layers
« Reply #2 on: August 25, 2008, 08:31:55 AM »
Mike,
    The order in which the layers are machined is entirely determined by the order in which you create the processes in SheetCAM.  Mach3 does not do any re-ordering, it smiply does what the G-code tells it to do.
