Hello Guest it is October 04, 2026, 08:21:46 PM
Author Topic: GEAR CUTTING TOOL - POST#2  (Read 18240 times)
« on: August 24, 2008, 09:44:24 AM »
The following pictures show a brass test cutter and the tool steel cutter meshed into the teeth of a cut 20 tooth 48 pitch gear.
Also the basic dimenesions used in later setup. The last picture shows tempering of the gear cutter. Picture color is off some as it's just a nice
dark straw color. Dimensions for the gear came form a spread sheet I created. You can get away with using a end mill of close size to the
tooth radius ( depends on what you want) but I wanted to see what my engraving machine could via multiple profile passes.
« Last Edit: August 24, 2008, 09:57:26 AM by RICH »
Re: GEAR CUTTING TOOL - POST#2
« Reply #1 on: August 24, 2008, 09:51:02 AM »
Nice, thanks for sharing Rich!
In reference to the hand written sheet picture, you really should upgrade to electric lighting nowdays as candles aren't really good for your eyes -  :D
« Reply #2 on: August 24, 2008, 10:03:03 AM »
But then I would need to get rid of the turkeys, all the feathers used for making motations, and wouldn't save on my electric bill. Not to mention the dried bark from the trees which it was noted on.
 :) RICH
Here is a sample from the spread sheet.
« Reply #3 on: August 24, 2008, 10:37:49 AM »
Just a silly answer to a possible question.
« Last Edit: August 24, 2008, 10:46:43 AM by RICH »
« Reply #4 on: August 24, 2008, 10:42:54 AM »
 :D
and thanks for the spreadsheet, I will probably need it someday  ;)
« Reply #5 on: August 24, 2008, 03:25:39 PM »
 :)  Good job RICH
  •  9,374 9,374
« Reply #6 on: August 25, 2008, 12:49:41 AM »
A bit off topic but I would love one of those R/C draglines.
