Hello Guest it is November 01, 2026, 10:12:54 AM
Author Topic: Some general questions  (Read 10184 times)
Offline Kristin D
  •  203 203
  • Take that you LazyCam, next stop the glue factory!
« on: August 23, 2008, 03:48:27 PM »
Say I take a DXF and load it, optimise, autoclean... How do I set the depth of cut? Is it some fixed default or do I have to use the button on the right to set it or the Layers Tab? Sure would be nice if there was at least a short quickstart guide. Reason I ask is I have used it for a few test cuts and it seems to be pretty random as to how far the cutter plunges or it could just be me.
Kristin
Re: Some general questions
« Reply #1 on: August 23, 2008, 04:15:48 PM »
Kristin, in the layers tab at the bottom, look for the "cut depth" box and in there, after the colon, put a minus sign and then put in your depth of cut.  :)
Hope that helps?
Offline Kristin D
  •  203 203
« Reply #2 on: August 23, 2008, 04:33:50 PM »
Thanks Dave,
That's what I wanted to know, if you have been following along here and the general forum, you know I just got the mill set up (well sort of) and am chewing a piece of 2x4 to bits just getting comfortable before I place an immoveable piece of metal in a cutter path and have something go sproing and shoot past my head. I figure it's best to make all my mistakes with a cheep Dremel burr and block of wood first then move on to bigger and better things.
Kristin
« Reply #3 on: August 23, 2008, 04:43:22 PM »
Indeed I have my friend and anytime I can contribute, I surely will-
Dave-
