Hello Guest it is November 01, 2026, 10:12:33 AM
Author Topic: another circle question  (Read 14486 times)
« on: August 21, 2008, 05:20:11 PM »
Using Illustrator CS3 to create a circle, export to dxf, then into lcam v.2.02. My problem is the circle for some reason shows as being oblong in lcam as well as Mach. Anyone have an idea or a trick with Illustrator that can correct this problem. Thanks, Jason
Adobe illustrator File
DXF from Illustrator
Jason
Re: another circle question
« Reply #1 on: August 25, 2008, 01:24:07 PM »
Optimized with illustrator before I exported to dxf...grouped, flatten transparency, converted to grayscale etc.
Any ideas?
« Reply #2 on: August 25, 2008, 01:36:10 PM »
Sorry, Jason, unfortunately I know nothing about adobe iilustrator.  ???
« Reply #3 on: August 25, 2008, 02:23:04 PM »
yeah, me either really...kinda learning as I go  :)
« Reply #4 on: August 25, 2008, 02:30:39 PM »
Before I completely throw in the towel, does adobe give you choices of DXF file types to save?
LazyCam likes autocad 11/12 type files. If there is something in your "save as" file type box that looks like that, that may be the problem right there-  :)
« Reply #5 on: August 25, 2008, 03:31:23 PM »
Yeah, it allows you to export to R13 or 2000 but still has the same results. Tried Corel 11 and that seems to work like it is supposed too. The Illustator interface I think is better but this export issue is a deal killer.
« Reply #6 on: August 25, 2008, 04:25:07 PM »
I can export from illustrator cs3 to a DXF then import into Corel Draw 11 and then export out again as a DXf and that works okay in lcam. Just a huge pain to have to do that everytime. Any other Illustrator users out there got any ideas?
Jason
