Hello Guest it is November 23, 2026, 01:41:35 AM
Author Topic: Mach 3 freezeing/simulation mode  (Read 17427 times)
« on: August 21, 2008, 10:33:59 AM »
I recently bought and downloaded mach3. I am running it on my desktop that currently does not have a parallel printer port. I plan on buying a PCI card with one soon but I still wanted to test the product out, without the parallel port.
On multiple occasions the machine would freeze. I tried installing the "special driver" and that did not help. When I first installed the software I did not check the "simulation mode".
Am I having problems because I have no parallel port and am not running in simulation mode or is there something else going on here? In addition to the freezing, I was having trouble jogging the axis. I went through the tutorials and believe I did everything right and am also attributing this to not actually running a cnc machine. Is there a way to easily go in and out of "simulation mode"?
Thank you for your time,
Adam
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
Re: Mach 3 freezeing/simulation mode
« Reply #1 on: August 21, 2008, 01:33:06 PM »
I have Mach3 on my office computer, as well as the one in the workshop.
I have nothing attached to the office computer, but I do have Mach3 set up on it, as though it were running a machine, e.g. the ports and pins are allocated correctly, and all the bits I do not have are all correctly ticked as not being present e.g. none of the switches are activated. (I set it up the same as the workshop computer so I can write GCode programs on it)
I assume you have the drivers installed, and the machine told you it was installed correctly.
What you can do is run a driver test - the program is in the folder (or on your Desktop).
What may be happening is that you are running programs that are waiting for inputs from a switch or something else that you have shown active but do not have.
You might try the Smooth Stepper as a better alternative to a PCI card.
The Smooth Stepper simply plugs into a USB port and provides more inputs and outputs than the standard card. It also generates the pulses for the stepper motor/servo motor drivers - and therefore take a major task off your computer - allowing it to run more efficiently.
« Reply #2 on: August 22, 2008, 10:35:33 AM »
So it turns out mach3 is not to blame; It freezes up with out without mach3 running and this is a recent thing.
I opened up the computer case and blew out the 4 year old dust build up and man it went flying... and kept on flying... and still more went flying. It seems to be running smoothly now without hiccups but I am keeping my fingers crossed.
On a separate note, I can't seem to get mach3 to jog. I listened to the setup videos. I have been able to jog no problem on my laptop in simulation mode, but not with the desktop running "real" I haven't had any luck. Any guesses?
Thanks again and my apologies for the post
« Reply #3 on: August 22, 2008, 12:14:10 PM »
Make sure you have the Jog Control active, it will have a green surround if it is.
