Hello Guest it is November 19, 2026, 03:06:17 AM
Author Topic: Modbus pcb from cnc4pc  (Read 13373 times)
Offline CJEls
  •  69 69
« on: August 19, 2008, 01:55:37 AM »
Hi All
I need some help on setting up this board.I have enabled the modbus and serial plugin in the pins and ports setup.I can see the inputs and output when testing the modbus .I can not get mach to see the inputs If I ase a brain to look for the inputs .I want to switch the coolant on and off. I wrote a brain using modbus input1 serai plug in,then use a no operation lobe doing a button press to switch the coolant on and off.What am I doing wrong.
CJ
Offline CJEls
  •  69 69
Re: Modbus pcb from cnc4pc
« Reply #1 on: August 19, 2008, 02:13:51 AM »
All
I tried to use Mach 3 turn version 2.63 and 3.041 but no joy. the other thing that bothers me is that if I use the old stile modbus I can get the board working.Any Suggestions.
CJ
