Hello
Guest
it is
November 19, 2026, 03:28:26 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
How to use the VB script instead of the Cycle start button??
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: How to use the VB script instead of the Cycle start button?? (Read 14114 times)
Edison
25
on:
August 18, 2008, 09:53:49 AM »
Thanks!
Edison
Logged
Edison
ger21
6,295
Re: How to use the VB script instead of the Cycle start button??
Reply #1 on:
August 18, 2008, 10:02:42 AM »
Can you explain what you want to do a little better? I don't quite understand what you want to do.
Logged
Edison
25
Reply #2 on:
August 19, 2008, 08:57:17 AM »
Hi, Gerry:
   I want to used the vb script code to instead the "run" function¡£
Edison
Last Edit: August 19, 2008, 09:00:33 AM by Edison
Logged
Edison
Carnoustie, Scotland
Reply #3 on:
August 19, 2008, 09:43:24 AM »
DoOEMButton(1000)
Logged
Print
Pages:
1
Go Up
« previous
next »
