Hello Guest it is November 19, 2026, 07:19:03 AM
Author Topic: Polite request  (Read 15165 times)
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Polite request
« on: June 06, 2006, 01:57:20 PM »
Dear Brian & Art,
would it be possible to add U,V and W to Mach3 turn, the X,Y and Z incremental moves are a major part of turning code.  Also could we have I,K and R automatic chamfer and radius.
This may seem petty but Mach3 mill is very comprehensive and turn seems to get the raw end of the deal.
Graham.
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: Polite request
« Reply #1 on: June 06, 2006, 09:23:23 PM »
Hi Graham:
    Turn does get the short end, no question. But it will be awhile till I can add soemthign like UVW incremental. I dont think Ill ever get raius and IK modes running like your thinking.  I need to finish the G100 plugin before I can add anythign more to MachTurn. Its sad, but its just where Im at... :)
Art
Offline Bear
  •  15 15
Re: Polite request
« Reply #2 on: October 22, 2006, 02:53:30 PM »
Hi Art,
Bear here ,been the backgroud for several years.Am an Artsoft junkie !
Is there anyway to connect ,rewire etc. to use Mach to an exhisting controller?
Bear
Offline ART
  •  1,703 1,703
Re: Polite request
« Reply #3 on: October 22, 2006, 02:57:27 PM »
Hi Bear:
  You can, or at least you can usualy use many of the components. The lucky ones find they already have step/direction drivers in theri controls, so they need only a breakout board,
for others, they can use th emotors and poiwer suplies, and just need drivers and a breakout board. All depends on the original control. Basically, you keep whatever you can, and replace
whatever wont work in a step/direction context..
ARt
Offline Bear
  •  15 15
Re: Polite request
« Reply #4 on: October 22, 2006, 03:23:18 PM »
Hi Art,
Pleasure to write with you.
as usual, i did not ask correctly.
I have a nuisance of a machine that has limited memory,graphics,etc.
were Mach is Great! MY ? IS Mach available comm.and if so where?
(interested in dealership in Texas ?)
Bear
