Hello Guest it is November 14, 2026, 04:05:24 PM
Author Topic: Encoder Wiring  (Read 15465 times)
Encoder Wiring
« on: August 14, 2008, 10:29:43 PM »
Hello,
Will it work to take a Differential encoder and connect it to a Single ended device like a Gecko by putting the A- and B- together with the 0v side of the 5v supply?
Just wondering...I have access to several REALLY reasonable. Otherwise, US Digital has what I need.
RC
Re: Encoder Wiring
« Reply #1 on: August 14, 2008, 11:28:09 PM »
Hi RC,
Yes you can use differential outputs and feed then to a single ended input as you want to do. Just use the A+ and B+. Leave the A- and B- UNCONNECTED.
Have a look at the following if it is not clear;
http://www.homanndesigns.com/EN004.pdf
Cheers,
Peter.
Homann Designs
Re: Encoder Wiring
« Reply #2 on: August 15, 2008, 12:06:28 AM »
VERY clear !
Thank you very much Peter.
RC
