Hello
Guest
it is
November 14, 2026, 04:05:12 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Stepper motor make a lot of noise
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Stepper motor make a lot of noise (Read 14994 times)
ostie01
628
on:
August 14, 2008, 02:52:46 PM »
Hi, I bought 2 of these stepper driver. ( for my double screws X axis)
http://www.kelinginc.net/KL6050WiringDiag.pdf
I also have one CW250 stepper driver (for the Y axis, no noise, run very smooth)
http://cgi.ebay.com/5-AMP-Bipolar-stepper-motor-Driver_W0QQitemZ330247578981QQihZ014QQcategoryZ71394QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
The two from kelingic technologies make a lot of noise.(A loud Hiiissssss)
1- What mean, CP+ and CP- and CW+ andCW-. (I know that this is steps and direction)
The KL6050 receive step and dir to the minus pin , CP- and CW- (CP+ and CW+ are at 5 volts)
The CW250 receive step and dir to the positive pins CP+ and CW+ (CP- and CW- are at ground)
Can I swap those connection, try to connect the KL6050(the one that make a lot of noise) and send signal to the CP+ and CW+ pins and ground CP- and CW- to test
Note: I have swapped driver to test and it is really the driver
Logged
Chip
2,055
Gainesville Florida USA
Re: Stepper motor make a lot of noise
Reply #1 on:
August 14, 2008, 07:08:31 PM »
Hi, Ostie01
Set your "Step/Dir Pulses" to 5 in Motor Tuning, CP -, CW -, to P-Port Gnd. and CP +, CW + to Step, Direction pin's.
Set your Steps Per to 2000 , Velocity to 20, Accl to 5, for a Test, Have some similar to these.
Hope this Helps, Chip
Logged
Print
Pages:
1
Go Up
« previous
next »
