Hello Guest it is November 26, 2026, 03:35:49 AM
Author Topic: Gear cutting wizard - no preview  (Read 30726 times)
Offline Sage
  •  370 370
« on: August 11, 2008, 09:19:16 AM »
Maybe I'm missing someting with the gear cuttig wizard but but when I click the preview button the preview scren is black. Preview works for some other wizards. It posts code which shows up in the toolpath of Mach so the problem must be with the wizard itself. Any suggestions?
Sage
« Last Edit: August 11, 2008, 10:09:18 AM by Sage »
Re: Gear cutting wizard - no preview
« Reply #1 on: August 15, 2008, 08:25:20 PM »
The problem is that the wizard generates some A axis moves, in a subroutine and the mach display code does not handle A axis moves. When Brian makes the graphic changes he is working on this may change.
The wizard generates working code, you just dont get the toolpath display
