Hello
Guest
it is
November 23, 2026, 09:15:53 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Just setting up - newbie question
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Just setting up - newbie question (Read 15540 times)
GVP
7
on:
June 04, 2006, 03:10:13 PM »
Greeting all!
Just getting to grips with Mach3. Any idea what would be causing my PC to beep approx. every 3 seconds whilst running the program? I can't seem to find any reference to this, so don't know where to look.
GVP.
Logged
Brian Barker
3,860
Re: Just setting up - newbie question
Reply #1 on:
June 04, 2006, 03:33:39 PM »
That sounds like you have a network card that is looking for the network... run the driver test and see what it looks like. If you are getting spikes you are going to have to optimize and that can be found on the Mach support page.
hope that helps
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Reply #2 on:
June 04, 2006, 06:29:26 PM »
Does it only beep when Mach is loaded? It could be motherboard monitoring software and your temps or fans are not what they should be or if its only happening when Mach is running maybe Mach and the monitoring software dont like each other.
Logged
Print
Pages:
1
Go Up
« previous
next »
