Hello Guest it is November 23, 2026, 09:39:37 PM
Author Topic: trouble with wizards -  (Read 17018 times)
davestea
« on: June 04, 2006, 10:55:20 AM »
the following are some of my observations and troubles with a couple of the wizards -
the OD groove wizard crashed M3 on two systems -
one has v84.000 and the other 001
one time it crashed so badly on the brand new system that I got with my Sherline lathe, that I couldn't even reboot.  It left a process running that I could not quit from the task manager.  Tried to reboot - but then it would not close down I guess because of the M3 process that would not unload.  Had to reset the system.  Hate to do that to Windows.
The id arc seems to want to cut into -X by .1" -- I went over that one a dozen times trying to figure out why it wouldn't work like I thought it should.  Reset home and x/z 0 several times - still goes negative -- even the code says -X.1??"
any help out there?  Suggestions?  Work Around?
thanks -
ds\
Re: trouble with wizards -
« Reply #1 on: June 04, 2006, 11:15:14 AM »
Are there ohters othere with the same problem?
Thank you
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: June 04, 2006, 11:51:16 AM »
There was a devide by zero error.. I added  some more error checking so it should be okay now  ;)
www.machsupport.com
davestea
« Reply #3 on: June 04, 2006, 01:02:12 PM »
I haven't played with all of them yet -
so far that was the only one that crashed the program --
so how do I get the new one?
did yoiu find anything on the id arc going into negative X?
thanks
ds\
