Hello
Guest
it is
October 16, 2026, 01:21:14 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
conect switches to lpt port
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: conect switches to lpt port (Read 11150 times)
mkink
4
on:
August 07, 2008, 04:50:58 AM »
I want to connect some switches to my second parallel port can i switch from ground to pin or is it important to use 5V extern for that?
can I connect them directly or should i use 5k resistor??
greets from sunny Austria
Carnoustie, Scotland
Re: conect switches to lpt port
Reply #1 on:
August 07, 2008, 05:20:16 AM »
If you are connecting direct to the PP then a normally open momentary switch to ground is all thats needed.
Last Edit: August 07, 2008, 05:22:37 AM by Hood
Print
Pages:
1
Go Up
« previous
next »
