Hello Guest it is October 17, 2026, 06:14:17 AM
Author Topic: SURFACE WIZARD  (Read 37860 times)
Re: SURFACE WIZARD
« Reply #10 on: June 04, 2006, 06:57:28 PM »
The Depth is the total depth that  it is going to cut and the Finish depth is the amount that is going to be left for a finish pass.
I think that is how it works from reading the code this morning  ;)
www.newfangledsolutions.com
www.machsupport.com
Re: SURFACE WIZARD
« Reply #11 on: June 06, 2006, 09:24:13 AM »
BRIAN, you posted the download above BUT ! this newbee don't know yet what to do with it or where to put it. I just haven't run into this yet and figured I'd ask instead of experimenting. Thanks
CRUISER
  Don
Re: SURFACE WIZARD
« Reply #12 on: June 06, 2006, 12:08:08 PM »
If you have Mach3 installed to the default location you place it in C:\Mach3\Addons\Surfacing with tool down in X
Re: SURFACE WIZARD
« Reply #13 on: June 06, 2006, 05:12:58 PM »
Thanks for all the info guys. I have finally got it  ;D
As an aside : Let me ask about the type of cutter shown in the wizard. I have a cheap (Asian) one that came with my Asian mill.
It has three inserts and I notice that they are not all at the same depth. Is this normal (each insert taking a progressively deeper bite) or are they supposed to be all at the same depth?
Re: SURFACE WIZARD
« Reply #14 on: June 06, 2006, 05:20:33 PM »
I would say they are supposed to be all the same depth.
