Hello
Guest
it is
November 18, 2026, 03:44:38 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
SURFACE WIZARD
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: SURFACE WIZARD (Read 38566 times)
Brian Barker
3,860
Re: SURFACE WIZARD
Reply #10 on:
June 04, 2006, 06:57:28 PM »
The Depth is the total depth that it is going to cut and the Finish depth is the amount that is going to be left for a finish pass.
I think that is how it works from reading the code this morning
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Cruiser
106
Re: SURFACE WIZARD
Reply #11 on:
June 06, 2006, 09:24:13 AM »
BRIAN, you posted the download above BUT ! this newbee don't know yet what to do with it or where to put it. I just haven't run into this yet and figured I'd ask instead of experimenting. Thanks
Logged
CRUISER
Don
Re: SURFACE WIZARD
Reply #12 on:
June 06, 2006, 12:08:08 PM »
If you have Mach3 installed to the default location you place it in C:\Mach3\Addons\Surfacing with tool down in X
Logged
JOE65
3
Re: SURFACE WIZARD
Reply #13 on:
June 06, 2006, 05:12:58 PM »
Thanks for all the info guys. I have finally got itÂ
As an aside : Let me ask about the type of cutter shown in the wizard. I have a cheap (Asian) one that came with my Asian mill.
It has three inserts and I notice that they are not all at the same depth. Is this normal (each insert taking a progressively deeper bite) or are they supposed to be all at the same depth?
Logged
Re: SURFACE WIZARD
Reply #14 on:
June 06, 2006, 05:20:33 PM »
I would say they are supposed to be all the same depth.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
