Hello Guest it is October 16, 2026, 12:26:22 AM
Author Topic: High Speed Jog and Running Speed  (Read 11984 times)
« on: August 05, 2008, 07:06:36 AM »
I would like to be able to have the high speed jog (hold down shift key and the arrow key) and the speed I have the program running at separate speeds.  I went into motor tuning, but they affect both the high speed jog and running speed.  Am I doing something wrong or is this not possible ?
Re: High Speed Jog and Running Speed
« Reply #1 on: August 05, 2008, 07:43:47 AM »
Your motor tuning determines your rapid speed and you dont want to adjust that as it could upset your motors making them stall etc.
 If you are just wanting to use the full Jog without having to press the Shift key then yoiu can. Press the Tab key and you will get a flyout, set the slow Jog to 100% by typing in the DRO and pressing the enter on your keyboard, now when you jog without presswing the shift key it will be at full rapid.
