Hello Guest it is November 10, 2026, 01:51:45 AM
Author Topic: Wizard Startup  (Read 32438 times)
Wizard Startup
« on: June 02, 2006, 09:06:28 AM »
Hello
Is it possible to have a VB script associated with the startup of a wizard to reset variables etc?
Re: Wizard Startup
« Reply #1 on: June 02, 2006, 09:47:02 AM »
Put a  file named init.m1s in the directory of the wizard and it will run the code on startup :)
Here is one that I used in the past:
www.newfangledsolutions.com
www.machsupport.com
Re: Wizard Startup
« Reply #2 on: June 06, 2006, 07:47:24 AM »
Marvellous - just the job - I'm guessing that you've done this before Brian  ;)
Re: Wizard Startup
« Reply #3 on: June 06, 2006, 12:41:56 PM »
 ;D
www.machsupport.com
