Hello Guest it is October 25, 2026, 04:28:42 AM
Author Topic: Rebuilding computer  (Read 16355 times)
Rebuilding computer
« on: August 03, 2008, 09:33:49 PM »
I had to format my hard drive and start over. Now Mach says my Gallil card does not connect after a reset. I have Galil tools on the computer and that sees the 1842 card ok. I notice my amps are not enabled which I suppose is because the Galil card isn't connected to Mach. Any ideas?
Re: Rebuilding computer
« Reply #1 on: August 03, 2008, 10:22:39 PM »
Did you save a copy of your xml file and did you put in the Mach 3 folder after reformatting? Did you also install the Gali Plug-in?
« Reply #2 on: August 04, 2008, 07:46:39 AM »
I could not save anything from the drive.
Yes, I did install the plugin. If fact, I tried installing it several times along with reinstalling Mach.
Mach does recognize the plugin.
« Reply #3 on: August 04, 2008, 01:41:13 PM »
Sounds like you'll have to set up another XML from scratch to me. Did you buy this machine ready to run or build it yourself?
« Reply #4 on: August 04, 2008, 02:06:58 PM »
Built it myself and it has been running great until my comp crashed. Yes I know, backup, backup and backup.
But I never had this much trouble the first time I installed the pulgin and got everything working. It went as slick as can be. I am using the latest MACH version, the one I had before was older. I doubt that is my problem.
« Reply #5 on: August 04, 2008, 02:55:24 PM »
I would think the new would be better but you never know...........
