Hello Guest it is September 22, 2026, 10:10:43 PM
Author Topic: Abnornal Refall Light  (Read 28946 times)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Abnornal Refall Light
« Reply #10 on: July 27, 2008, 06:18:05 PM »
Hi, Inivator
It could be a number of things, Acceleration set a little to high, If there are any G00 moves Velocity to high, Power Supply volts or amp's not sufficient, Current on your stepper board set low.
Tell us about your setup.
Thanks, Chip
« Reply #11 on: July 27, 2008, 06:24:09 PM »
NOTHING IN THE SET-UP HAS CHANGED.  THE POWER SUPPLY AND BOARDS ARE THE SAME SINCE DAY ONE.  THE ONLY CHANGE THAT I HAVE MADE IS TUNING OF THE MOTORS.  ALL ARE TUNED TO ABOUT THE SAME SPEED AND ACCELERATION.  I HAVE SET THE LOOK-UP TO 200, IT WAS 2.  I HAVE NOT RUN THE MACHINE SINCE THE LOOK-AHEAD WAS CHANGED.  I HOPE THIS WILL HELP THE PROBLEM..
INIVATOR
« Last Edit: July 27, 2008, 06:25:53 PM by inivator »
Offline Chip
  •  2,055 2,055
« Reply #12 on: July 27, 2008, 06:36:47 PM »
Hi, Inivator
Have you done these short segment type files in the past.?
Is Mach setup in CV or Exact Stop mode in Config, General Config.?
A Look Ahead of 200 is big and probably won't help if your in Exact Stop mode.
Chip
« Reply #13 on: July 27, 2008, 06:42:48 PM »
IT IS IN THE CV MODE.....................
INIVATOR
« Reply #14 on: July 27, 2008, 06:47:01 PM »
Turn your acell down a bit and try again.
« Reply #15 on: July 27, 2008, 06:51:36 PM »
I'LL TRY THAT...THANKS.  I WON'T BE DOING ANYTHING ELSE TODAY, THE BOSS-LADY SAYS IT IS HONEY-DO TIME.
AGAIN THANKS ;D ;D ;D
INIVATOR
