Hello Guest it is November 19, 2026, 04:16:18 AM
Author Topic: Inline variables and loops?  (Read 26869 times)
3IMOH
« on: May 31, 2006, 05:12:16 PM »
Hello-
I have been using a shopbot for a while now, and I am considering building a router that would be controlled via Mach 3.  The shopbot code is a similar syntax to g-code, but one thing it has is the ability to specify variables in the file instead of hard coding feedrates, etc. It also has the ability to use conditionals and loops, etc.
Is there something similar that can be done with Mach 3 and g-code?
thanks,
Howie
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Inline variables and loops?
« Reply #1 on: June 01, 2006, 02:30:29 AM »
Yes, you can do things like this:-
#100=5
G00 X[#100*10] Y[#100*10]
M30
Graham.
« Last Edit: June 01, 2006, 02:45:31 AM by Graham Waterworth »
Offline Tarak
  •  229 229
« Reply #2 on: June 24, 2006, 07:49:10 PM »
Can you do any commands like, IF [#101EQ0] GOTO10?
Is it possible to get a list of all the possible variable commands.
