Hello Guest it is November 07, 2026, 01:51:19 AM
Author Topic: Format strings for sliders ???  (Read 13809 times)
Offline Greolt
  •  956 956
« on: July 22, 2008, 03:32:26 AM »
Is there any info anywhere on the format strings for sliders in Screen4?
Greg
Re: Format strings for sliders ???
« Reply #1 on: July 22, 2008, 09:43:09 AM »
Hey Greg, not sure if there is any info posted but if you tell me what your tryiong to do, I'll try and see if I can figure it out and post what I find.
« Reply #2 on: July 22, 2008, 10:28:53 AM »
I don't have a copy installed here at work, but if I recall, the L is the min value, H is the max value. I looked at the ones in the standard screen, they were something like STDL10H250 with the standard DRO string added on at the end. I found that if I removed the D (I think), It would not display the numbers with the slider. I didn't need them since I had a DRO displaying them. I wanted to make a horizontal slider, and Art said it was possible, but the info he gave didn't appear to be correct.
If there is any info out there, I couldn't find it.
« Reply #3 on: July 23, 2008, 08:00:18 PM »
Just checked, and I used this to get a slider that did NOT display the value.
SL10H200%0.3f
goes from 10 to 200. Even though it doesn't display the value, I accidentally found out that it didn't work correctly if I omitted the %0.3f
