Hello Guest it is November 22, 2026, 07:09:14 AM
Author Topic: Figuring out a linear accuator stepper  (Read 16489 times)
Offline Kristin D
  •  203 203
  • Take that you LazyCam, next stop the glue factory!
« on: July 19, 2008, 06:31:24 PM »
I just got a Hayden accuatiator 1.8 deg/step and I think 0.00125 linear motion/step so how do I set up the steps/inch I can set my HobbyCNC board to microstep of 2/4/8 which I suppose I should do. So is it 1/0.00125 x 200 x microsteps = 1 inch???
Kristin
Re: Figuring out a linear accuator stepper
« Reply #1 on: July 19, 2008, 07:10:23 PM »
1 rev of your motor will be 1/4" Linear movement (200 steps  @ 0.00125") , so 4 revs of your motor is 1 inch. 4 x 200 x MicroStep= steps per inch.
Offline Kristin D
  •  203 203
« Reply #2 on: July 19, 2008, 07:28:32 PM »
Thanks Hood,
spent way to much time during math class staring out the window it seems. Kind of explains why when I entered g1 z1 it ran out of room! Had SPI set to 20,000 should be 6400 at 8 microsteps.
Kristin
« Reply #3 on: July 19, 2008, 07:31:34 PM »
Sometimes the more you look at something the harder it seems to be to work it out, take a step back and look again and often things are clearer :)
Offline Kristin D
  •  203 203
« Reply #4 on: July 19, 2008, 07:48:23 PM »
Hood,
That was the easy part, got it running semi-tuned the motor, now I have to figure out the mechanical linkage and setup!  ;D
Kristin
« Reply #5 on: July 19, 2008, 07:49:19 PM »
LOL
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #6 on: July 26, 2008, 11:21:28 PM »
Hi, Kristin
In the post you deleted, Did you try changing the Motor Outputs, Low/Actives to the opposite State for step/direction's ?
It's sorta been a G-oust Town Around Hear.
Chip
