Hello Guest it is November 23, 2026, 10:15:49 PM
Author Topic: Motors move on start up  (Read 15109 times)
« on: July 19, 2008, 12:52:56 AM »
Couldn't find a post on this. I just wired up another KL-4030 set of drivers with 35 VDC 10 amp supply and Three 425 oz inch motors. Ok the problem when i flip the switch the motors start moving and jerk a little but never change direction. I thought the motors where suppose to lock up  when power was applied. Any help on this one would be much appreciated.
Travis
Re: Motors move on start up
« Reply #1 on: July 19, 2008, 02:44:48 AM »
Check your wiring carefully and also check your pin asignment in Mach.
« Reply #2 on: July 19, 2008, 11:20:07 PM »
Thanks Hood
I had a loose ground. All is well now.
Travis
« Reply #3 on: July 20, 2008, 01:55:32 AM »
Great :)
