Hello Guest it is October 14, 2026, 03:42:21 AM
Author Topic: Wiring motors  (Read 40893 times)
Offline Robhi
  •  138 138
Re: Wiring motors
« Reply #20 on: July 31, 2008, 05:33:17 PM »
OK ... I am going to do so, hoping it will work.. if not never mind..
thank you again , have a nice night
Robhi
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
Re: Wiring motors
« Reply #21 on: August 02, 2008, 12:19:56 PM »
Robhi -
Sorry I missed this post the last time I was on the net. Hood has given you good advice - is he says the drives you have bought also do step and direction pulses, then use the drives you have bought to get started, You can wire them in parrallel if you wish, the drive is linited to 2.5amp so will not give you full speed/torque but will be better than wired in series.
The drives I use are the Gecko 201 - the simplest one you can buy. If one of your drives fails, then buy a Gecko to replace it.
Best of luck
« Last Edit: August 02, 2008, 12:31:19 PM by jimpinder »
