Hello Guest it is October 14, 2026, 04:27:29 AM
Author Topic: Wiring motors  (Read 40894 times)
Offline Robhi
  •  138 138
Re: Wiring motors
« Reply #10 on: July 31, 2008, 04:33:49 PM »
Hello again,
Sorry to bother You, I have already bought the motors, and the drive as well..
To Jimpinder, Could you tell me which drive you use Gecko drive.. ? they are a lot of drives that have this name..
i guess that am going to do the same this as you, that will help me a lot.. also if I can use my motors with this drive.
thank you
Robhi
Re: Wiring motors
« Reply #11 on: July 31, 2008, 04:53:32 PM »
G201,G202, G203, G210 and G212 are the stepper drives from Gecko.
The 201,202,203 are fixed at 10 microsteps the 210,212 have full, half 5 and 10.
Best bet for you I would think would be to stick to the 201,202,203. Probably actually 201 or 202 would be ones I would go for.
Offline Robhi
  •  138 138
Re: Wiring motors
« Reply #12 on: July 31, 2008, 05:00:43 PM »
Thank You Hood,
So all what I need is to buy the G203V. that Will be enough  to drive my 3 motors? or I have to buy other things beside the G203V?
Robhi
Re: Wiring motors
« Reply #13 on: July 31, 2008, 05:03:13 PM »
You will need 1 drive for each motor you have.
Offline Robhi
  •  138 138
Re: Wiring motors
« Reply #14 on: July 31, 2008, 05:07:23 PM »
So I need 3 drives for my 3 motors.. is OK..
these 3 drives will be connected to gother ? is there any site which illustrate , explain how I can do that?
Sorry I may make you laughing.. but never mind
Robhi
Re: Wiring motors
« Reply #15 on: July 31, 2008, 05:19:24 PM »
No laughing here, only time I laugh is when people dont ask questions :)
Heres how things work
 Your parallel port cable comes from the computer, it connects to a breakout board (can just solder direct to cable but breakout is better) Then the drives connect via Step and Direction pins to the breakout. The motors connect to the drives and also a power supply connects to the drives. Limit switches and other I/O you may have connect to the breakout board.
 For the Geckos a power supply of between 24 and 80V DC is needed, they are easy enough to make, I will post a link in a few mins to a pdf that tells you how. The more voltage you supply (80v max) the faster you will manage to get your motors turning :)
Re: Wiring motors
« Reply #16 on: July 31, 2008, 05:22:50 PM »
OK heres the link to the power supply building pdf.
http://campbelldesigns.net/how-to-build-a-power-supply.php
Oh meant to ask, where are you from Robhi?
Offline Robhi
  •  138 138
Re: Wiring motors
« Reply #17 on: July 31, 2008, 05:25:25 PM »
Thank you ,
I am from palestine, but I live in Switzerland since long time.
thank you again Hood
Robhi
Re: Wiring motors
« Reply #18 on: July 31, 2008, 05:26:20 PM »
No problems :)
Re: Wiring motors
« Reply #19 on: July 31, 2008, 05:29:42 PM »
Robhi
 just looked back at your earlier posts and the drives you have will probably do, they accept step/direction input and that is what Mach puts out.
 Geckos would get you moving faster probably but on a small machne it may not be needed :)
