Hello
Guest
it is
November 23, 2026, 10:53:36 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
power supply
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: power supply (Read 16452 times)
Robhi
138
power supply
on:
July 10, 2008, 02:41:45 AM »
Hello,
I would like to know if I could use a power supply of 24 volt, 15 ampère for XS-3525/8S-4 of XYLOTEX.. I do not know whether it is dangers or not..
thanks in advance for your help
Robhi
Robhi
138
Re: power supply
Reply #1 on:
July 10, 2008, 02:52:38 AM »
sorry, you may need more information about my stepper motors they are as the following:-
Code 160-010-00400
Type Hybrid Stepper
Holding Torque 220Ncm
Step Angle 1.8°
Rated Voltage 7.5V
Rated Current 2.5A/Phase
No. of Wires 8
Size 57x57x115mm
Shaft Dia. 10mm
Shaft Length (Front) 30mm
Shaft Length (Rear) 30mm
Net Weight 1.74kg
thanks
Robhi
Re: power supply
Reply #2 on:
July 10, 2008, 06:14:56 AM »
"I do not know whether it is dangers or not.."
When it comes to personal safety nobody can speak for someone elses use of devices, machine, or human actions.
That burden falls on you and the manufacturer and it's totaly your responsibility to pursue until satisfied.
In fact "SAFETY FIRST" should just be a way of life.
If you have safety concerns in regards to the use and integrity of a kit you should contact the manufacturer.
As a packaged kit the product sold should preform within manufacturers recomendations for use.
PS: No experience with that particular kit.
Robhi
138
Re: power supply
Reply #3 on:
July 17, 2008, 02:06:27 PM »
Hello,
Thank you for answering, I wanted to say if I use more than 10 ampère ..I guess that if I use more than 35 volt it Will be dangerous, but for using more than 10 ampère.. really i do not know..
thanks a lot
Robhi
Robhi
138
Re: power supply
Reply #4 on:
July 17, 2008, 03:51:48 PM »
Hi ,
As you told me , I contacted the manufacturer of the drive , I was told that the power supply of 24 volt , 13A is very fine for this drive..
thank you so much
Robhi
Kristin D
203
Take that you LazyCam, next stop the glue factory!
Re: power supply
Reply #5 on:
July 17, 2008, 04:50:13 PM »
Robhi,
Just a suggestion, rather than spread your questions over several different posts/topics it's easier for people to follow along on one thread and see your overall questions/problem.
Kristin
Print
Pages:
1
Go Up
« previous
next »
