Hello Guest it is November 23, 2026, 12:07:26 AM
Author Topic: Need VB Terms explanation  (Read 80741 times)
« on: May 28, 2006, 03:21:25 PM »
Hi Brian
Here follow a snippet out of a Wizard..........
                              X = Fmtn(XNeg + X,4)
Can you please give me a explanation of the term ......Fmtn and what is the 4 in X,4
Thanks for your time
Deon
If A is a success in life, then A equals X plus Y plus Z.
                               Work is X: Y is play and Z is keeping
                                                             your mouth shut.
Re: Need VB Terms explanation
« Reply #1 on: May 28, 2006, 05:13:57 PM »
Deon this is to format the number that is going to be output... So nFmt(X +2 /y,4), this will do the cals to figure out what the point will be and then it will output the number as follows 0.0000
Hope that helps
Brian
www.newfangledsolutions.com
www.machsupport.com
