Hello Guest it is October 22, 2026, 05:08:48 PM
Author Topic: Turn-XML-Tool Table  (Read 14959 times)
Turn-XML-Tool Table
« on: July 02, 2008, 01:31:36 PM »
Hello,
I had 5 tools set up in the Turn Tooltable.
Then ran a different XML to illustrate some configuration settings for Spindle control.
When I re-loaded my original XML, the Tooltable was empty......reset to all 0's.
I assumed it would be saved in the XML....should it have been ?
If not, how is it to be saved ?
RC
Re: Turn-XML-Tool Table
« Reply #1 on: July 02, 2008, 01:53:28 PM »
Also.....I transferred the XML from 1 PC to another with a Flash drive. Then I opened the file on the 2nd PC and the Pin assignments looked to be all out of whack. There were pins for Limits and Homes that I don't even have Enabled.
I know very little about what I was looking at though.
Could it have gottent garbled during the x-fer ?
RC
« Reply #2 on: July 02, 2008, 02:47:18 PM »
RC, I have never seen this personally, but I haven't had a need for the tool tables as of yet except for playing. Sounds to me like you may have saved/transfered/over written the wrong XML.  :'(
« Reply #3 on: July 02, 2008, 03:14:12 PM »
Tool3.dat in the profiles macro folder is your tooltable.
« Reply #4 on: July 02, 2008, 10:28:37 PM »
thanks,
rc
