Hello Guest it is September 18, 2026, 11:42:02 AM
Author Topic: Z axis on/off  (Read 21317 times)
Z axis on/off
« on: May 26, 2006, 02:15:14 PM »
I am a new Mach3 user trying to figure out how to make this program work.  I've got my X-Y axis working on my router.  I can turn the spindle on and off.  I am running into a problem though, with the Z axis.  The Z on this new router is an air cylinder so it is either on or off, but my G-code is coming from being run on a 3 axis CNC (G0 Z.060).  How can I get Z to "turn on" when Z plunges and "turn off" when it retracts.  All Z Values in the code are either .060 deep or 0 (Reason why I can fix Z depth on this new router).  Any thoughts would be appreciated!  Roger
Re: Z axis on/off
« Reply #1 on: May 26, 2006, 03:22:37 PM »
This can be done a few ways.. We could have the Macropump look at the Zvalue and IF it is Negitive will push the Zdown and if it is positive it will pick it up.
Is that what you are looking for?
www.newfangledsolutions.com
www.machsupport.com
Re: Z axis on/off
« Reply #2 on: May 26, 2006, 03:25:18 PM »
Exactly. That would be perfect....How do I do that?? Thanks.  Roger
Re: Z axis on/off
« Reply #3 on: May 26, 2006, 03:41:11 PM »
Put code in the MacroPump.m1s like this:
if(GetDRO(2 < 0.0 ) Then
   ActivateSignal(Output1)
else
  Deactivatesignal(Output1)
end if
There is a Wiki on the support page telling how to do a Macro pump under the Modio.. Hope that helps
Brian
www.machsupport.com
Re: Z axis on/off
« Reply #4 on: May 26, 2006, 03:47:23 PM »
Thanks.  I'll give it a try.  Roger
Offline Bengt
  •  54 54
    • Private CNC site
Re: Z axis on/off
« Reply #5 on: July 14, 2006, 04:40:59 PM »
Brian
Can you point me to this page as I cannot find it, thanks
Bengt
Bengt
