Hello Guest it is October 25, 2026, 03:40:04 PM
Author Topic: help  (Read 16308 times)
gary
help
« on: May 25, 2006, 03:07:15 PM »
Hello
Just downloaded the new version of mach3 with lcam, i,m using it on my newly built cnc lathe & am a newcomer to cnc work. I am able to import an autocad drawing in dxf & save in Gcode but when putting it in the auto screen the file is loaded vertical i,e it would be a facing profile rather than a turned spindle as drawn.
Also is there a part of lcam that will be able to work out the roughing cuts if the stock diameter is given.
thanks help Gary.
Re: help
« Reply #1 on: May 25, 2006, 03:53:41 PM »
Gary Lcam can not do Lathe at this time :( It is one the list because Art needs to have it for his lathe  ;D
www.newfangledsolutions.com
www.machsupport.com
gary
Re: help
« Reply #2 on: May 26, 2006, 03:11:04 AM »
Ok thanks Brian, hears looking forward to when it can.
cheers Gary
